Sinds een paar dagen heb ik een UXG-Lite als router voor mijn Freedom glasverbinding. Via een script zet ik de MTU naar de juiste waardes:
!/bin/sh
Replace 1492 with 1500 in /etc/ppp/peers/ppp0
sed -i ‘s/ 1492/ 1500/g’ /etc/ppp/peers/ppp0Set MTU for eth1 and eth1.6
ip link set dev eth1 mtu 1512
ip link set dev eth1.6 mtu 1508Bring eth1 down and then back up
ifconfig eth1 down
ifconfig eth1 upKill all pppd processes
killall pppd
ifconfig geeft dit resultaat:
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.1 netmask 255.255.255.0 broadcast 0.0.0.0
inet6 2a10:x:289d::1 prefixlen 64 scopeid 0x0
inet6 fe80::dab3:70ff:fe93:b65e prefixlen 64 scopeid 0x20
ether d8:b3:70:93:b6:5e txqueuelen 1000 (Ethernet)
RX packets 376384 bytes 457595082 (436.3 MiB)
RX errors 0 dropped 21 overruns 0 frame 0
TX packets 327160 bytes 63673254 (60.7 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 769592 bytes 604496319 (576.4 MiB)
RX errors 0 dropped 104 overruns 392 frame 392
TX packets 714788 bytes 282419579 (269.3 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1512
inet6 fe80::dab3:70ff:fe93:b65f prefixlen 64 scopeid 0x20
ether d8:b3:70:93:b6:5f txqueuelen 1000 (Ethernet)
RX packets 415405 bytes 190668523 (181.8 MiB)
RX errors 0 dropped 0 overruns 0 frame 53982
TX packets 545977 bytes 505506471 (482.0 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0eth0.2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.2.254 netmask 255.255.255.0 broadcast 0.0.0.0
inet6 2a10:x:289d:2::1 prefixlen 64 scopeid 0x0
RX packets 226611 bytes 110307647 (105.1 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 252232 bytes 170667909 (162.7 MiB)
eth0.10: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.16.0.254 netmask 255.255.255.0 broadcast 0.0.0.0
inet6 2a10:x:289d:1::1 prefixlen 64 scopeid 0x0
RX packets 1055 bytes 127403 (124.4 KiB)
TX packets 765 bytes 90063 (87.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0eth0.1010: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.0.254 netmask 255.255.255.0 broadcast 0.0.0.0
RX packets 25015 bytes 3657882 (3.4 MiB)
TX packets 134221 bytes 46688078 (44.5 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0eth1.6: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1508
RX packets 407535 bytes 173316676 (165.2 MiB)
TX packets 545862 bytes 503996071 (480.6 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0honeypot0: flags=195<UP,BROADCAST,RUNNING,NOARP> mtu 1500
inet 192.168.1.99 netmask 255.255.255.255 broadcast 192.168.1.99
inet6 fe80::f008:5dff:fe8e:7a3d prefixlen 64 scopeid 0x20
ether f2:08:5d:8e:7a:3d txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 155729 bytes 156456230 (149.2 MiB)
TX packets 155729 bytes 156456230 (149.2 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0ppp0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 45.x.x.x.x netmask 255.255.255.255 destination 185.93.175.230
inet6 fe80::c965:92eb:11f6:1207 prefixlen 128 scopeid 0x20
ppp txqueuelen 3 (Point-to-Point Protocol)
RX packets 50075 bytes 28349875 (27.0 MiB)
TX packets 45420 bytes 13561180 (12.9 MiB)
Waar volgens mij alles goed lijkt te staan. Als ik ping met een MTU naar een ipv4 adres gaat dat goed:
ping radio.nl -c3 -s 1468 -M do
PING radio.nl (37.48.79.75) 1468(1496) bytes of data.
1476 bytes from 37.48.79.75 (37.48.79.75): icmp_seq=1 ttl=57 time=5.35 ms
Maar met een maximale MTU ipv6 waarde van 1452 bytes gaat het mis, en krijg ik geen antwoord.
ping freedom.nl -c3 -s 1452 -M do
PING freedom.nl(haproxy.frontproxy.fi001.nl.freedomnet.nl (2a10:3780:2:52:185:93:175:46)) 1452 data bytes
— freedom.nl ping statistics —
3 packets transmitted, 0 received, 100% packet loss, time 2008ms
Gewoon pingen naar een ipv6 adres gaat wel zonder problemen.
Heeft iemand een idee wat er fout zit in de configuratie?
